Re: Cub in 1750 lb. pulling class
Posted by scot in pa on June 29, 2009 at 11:44:16 from (12.171.162.28):
In Reply to: Cub in 1750 lb. pulling class posted by AlexLV on June 24, 2009 at 12:52:31:
Most places I've been haven't been too picky what you use for weights. Chains, binders, bottle of water, big-@&& crescent wrench. You can get close with some imagination. I think you'd want your weight on back with the cub if you can add any. Talk to them if you are a bit over, they may let you pull your first time as long as you cut the weight before you go back. I've even seen guys recruit the 8 year old son of the guy he parked beside to make weight.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
