Posted by D Slater on June 29, 2009 at 12:53:26 from (71.164.53.42):
In Reply to: Super mta posted by cazzhrdwd on June 28, 2009 at 17:54:53:
Serial # tag should fall from 60001 to 83523, unless its a diesel it should have a C 264 engine. Depending on the tractor serial # the original engine serial # should be between 113387 to 136833. Rare to find a original one with date codes later than september of 54. Some have some 53 castings on them. Never saw one with a casting earlier than july of 53. There could be though. make sure the hood is longer than a SM or M and that it has braces and the heat shield on manifold side underneath. Could be or may not be a tip off that its modified.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
