I like the idea of a diode, if you go to a voltage regulator we are in the situation we were discussing a few days ago about excess current flow through the points on the reglator as the generator that originally used a cut out and high low charge on light switch has a field coil draw of 3.5 to 4.5 amps where as the generator using a voltage regulator has 2.5 to 2.7 amp draw. Points in regulator do not handle the higher amperage well causing eratic regulation and short reglator life. My opinion. You could also just find an old regulator and use only the cutout portion of it as they are usually in good shape.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
