Re: International A died and not starting
Posted by ScottyHOMEy on June 30, 2009 at 06:03:13 from (64.222.222.78):
In Reply to: Re: International A died and not starting posted by Jeff Z. on June 30, 2009 at 04:48:45:
Agreed. The difference is that if the points are bad, it likely won't run any better than it did at the end of the day yesterday.
A coil on its way out will often run reasonably well when cool, but fail as it heats up. If he has that experience, I'd suspect coil over points as the problem.
