Re: International A died and not starting
Posted by El Toro on June 30, 2009 at 07:09:54 from (64.12.116.73):
In Reply to: International A died and not starting posted by Larry Hardesty on June 29, 2009 at 20:30:18:
If you have the 6 volt coil without a ballast resistor you may have fried your coil. Pull off a plug wire asap when it quits and check for fire to the plug. If its weak fire or no fire the condenser would be cheapest to replace. If that doesn't fix it buy Napa's coil with a builtin resistor p/n IC14SB for about $18.00. Hal
