Posted by D Slater on June 30, 2009 at 07:57:37 from (72.65.152.136):
In Reply to: Re: Super mta posted by rustred on June 29, 2009 at 19:23:00:
Not around to many SW6TA tractors, but most of the 6 series must have put the radiator the same distance from the engine. The fan shroulds are the only other ones the same as a SMTA. Picked up a few from salvage tractors to use on SMTA. Not sure but think there was some change in the super 6 hoods compared to before and after channel frames started. On a SMTA non diesel the hood is longer because the front bolster moved the radiator forward, not because of the T/A housing.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
