Re: Checking/Setting Timing for a IH 544 C-200 engine?
Posted by John G. Hasler on June 30, 2009 at 10:38:45 from (174.124.18.71):
In Reply to: Checking/Setting Timing for a IH 544I C-200 engine? posted by Eric Kaltenbach on June 30, 2009 at 08:23:57:
> ...how is the timing done on this tractor?
You loosen the bolts on each side of the distributor and rotate it. There are timing marks scribed onto the front pulley but they can be hard to see. You line them up with the sharp pointer sticking out of the front cover on the left side. Adjust for 0 degrees at low idle (425) and 20 degrees BTDC at high idle (2420 gear drive).
Your problem sounds like it's with the governor linkage to me, though. I suggest that you buy a set of manuals.
