Re: Plugging Hole in Radiator for an H
Posted by Brownie 450 on June 30, 2009 at 10:40:44 from (216.51.158.253):
In Reply to: Plugging Hole in Radiator for an H posted by Joe Farmall on June 30, 2009 at 06:18:05:
A hole that small is able to be fixed on the tractor. Carefully pull enough fins away in the area of the hole so that you can get in with a piece of clean fine emery cloth. Work with the cloth enough to see clean, bare brass around the puncture. I use Kester acid core solder & a hot soldering copper for the repair. If the tube is VERY solid, you might be able to use a propane torch for heat. This is all done with liquid out of the radiator of course. Rinse with soda water mix after the repair.
