B414 leaking oil from left rear axle end.
Posted by ronb.vip on June 30, 2009 at 15:34:43 from (74.198.8.58):
I checked the tran level plug and oil immediately started coming out. Could the trans be too full causing pressure to cause the rear axle leak? The manual is not too clear on where the level plug is. I believe it is the plug on the driver right side level with the floor board and adjacent to the brake pedalsz/...right. Anyone think I should empty the level so that it stops at the bottonm of the plug as it should?
Thanks
