Dave, I am right with you same problem. I have been chasing water problems around on my 10-20 Head I think I got them all. I have had this tractor started with hand crank 3 weeks ago, But have not been able to do so now, it pops and fires after sitting but than floods. I pulled the air mix screw out of bottom of carb and watch for fuel leaking. Pulled cork and install a recoatsed one. Took out needle valve and put valve grinding compound on it and relapped it into seat put it all back together and leak seemed to stop. When you put your needle back you need to turn carb upside down so it goes in the chamber and also upside down to measure your floot level. If your floot will not shut off the gas flow it will run right into the manifold and when you crank it the gas floods the plugs and it will not start. oldiron29
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
