Re: Farmall 460 weak hydraulics when hot
Posted by JLE on June 30, 2009 at 18:40:30 from (68.28.138.224):
In Reply to: Farmall 460 weak hydraulics when hot posted by Matt460 on June 30, 2009 at 17:19:27:
If you know someone with a flow rater, it might be worth the charge to check the system. A relief valve may be fading out also, it would be a shame to replace pump and not be that. Do you have aux valves, if so are they acting the same way?? When you had pump apart, did you pull the wear plates and check the seals under it.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
