Re: Farmall 460 weak hydraulics when hot
Posted by Ted in NE on June 30, 2009 at 20:25:48 from (74.85.105.17):
In Reply to: Farmall 460 weak hydraulics when hot posted by Matt460 on June 30, 2009 at 17:19:27:
Make sure the hoses to the hyd cyl. for the fast hitch are in the right ports. There is a check block to hold the fast hitch drawbar up. As you stand behind the tractor. The 2 ports in the seat box that are furthest apart are the ones the cyl hoses go to. Also the hose on the cylinder that is closest to the center of the tractor goes to the top port on the check block.
If the hosed are wrong or the cylinder seals are bad it will leak down & keep your hyds on pressure, heating the oilcauseing the problem you describe.
