Normal operating temperature is 100 degrees over ambient temperature. Anything above that would be concidered hot. If the system is indeed running hot then the system is staying on high pressure. The unloading valve is suppose to dump oil back to the sump when you are not using your hydraulics to prevent the oil from getting hot. Hot oil is thin and easier to slip by the gears from the high pressure side of the pump to the low pressure side. Does it sound like the engine is laboring all the time like you are constantly using the hydraulic system. Sometimes the tel-a-depth valve spool will hang up in the valve and not return to neutral and keep the system on high pressure. If you have weak hydraulics to the auxillary valve only then you need to check for a blown o ring on the check valve piston. Chuck
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
