Re: Farmall 706 Gear Noise
Posted by Mark in Upstate on July 01, 2009 at 04:47:20 from (24.97.31.30):
In Reply to: Farmall 706 Gear Noise posted by georgegcms on June 29, 2009 at 18:50:21:
Are the brakes good? If the discs break from the spline this will make a similar noise.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
