Re: M Fluids
Posted by Janicholson on July 01, 2009 at 07:02:47 from (199.17.6.167):
In Reply to: M Fluids posted by RickA on July 01, 2009 at 06:44:27:
Sure:
Engine: 15-40 Rotella (shell) 8 quarts and a new filter. pour in 6. run it then pour in more until it comes out the top petcock.
Liftall hydraulic. If using the unit with shared equipment Hytran, or JD spec Hydraulic fluid. 6 quarts. If stand alone, 20wt non detergent oil will be fine.
Trans about 6 gallons of 80-90 gear oil. Drain from all diff/trans plugs, and rinse with diesel. Fill to within a half inch of the level plug near the clutch rod, left side. Plug on deck to fill. JimN
