Hal, Interesting. My magneto has been disconnnected. The center wire out of the distributor goes to the coil.
Now, I am not seeing ballast resister on mine either before or after the coil. I assume unless there is an internal resister there should be one before a 6 volt coil ...and should there be one after a 12 volt coil??
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
