Re: M Fluids
Posted by Bob M on July 01, 2009 at 07:24:20 from (151.190.254.108):
In Reply to: M Fluids posted by RickA on July 01, 2009 at 06:44:27:
Jim's advice below is right on EXCEPT: The M tranny holds 13 gallons, not 6!
Be prepared before you pull the tranny drain plug. If water's gotten into the housing you could get 14 - 15 gallons before it stops draining!
Also if the tractor has a belt pulley another quart or so is held in the gearbox. Loosen the gearbox to drain the old oil. Then tighten it back up and add a quart of fresh thru the plug at the top. Or operate the pulley for a few minutes after refilling the transmission - the gearbox will be splash filled from the main transmission.
