Dave-Have been admiring your work, and would like to help. I don't have a 10-20, but the carb would seem to be similar to our 1927 Farmall Regular, or 1925 15-30. If fuel is dripping through the copper tube, then I believe that your float is not stopping the flow of fuel. I think the copper pipe is more or less of a vent pipe, for the fuel bowl. Your float is probably cork. If it is not new, I would consider getting a new one. Old ones can get soggy, and too heavy. I have let them dry out, for a long time, and coated them with shellack, and have had that work. Also, if you can see fuel running through that copper vent tube, then you probably have the tube to the air cleaner removed. Our 15-30 won't run with that tube removed. Must need the resistance of the air cleaner to draw the fuel through the carb. Sometimes a float will hang up, and you need to tap on the bowl, to free it up, and keep the carb from running over. Hope some of this helps. Lots of guys on this forum know more about these, than I do. Hope to see your tractors at the Cedar Valley Engine Club show.
Loren - I'll be at the Cedar Valley show. Al Koenigsfeld is my uncle and I designed the www.restorerosevillestore.com website for the store. I was going to drag these old tractors to my farm for looks but Al suggested restoring them for the show at Roseville. I just need to get them running consistent now.
My float looks like a new dry cork that has been varnished. I guess I will spend more time testing the float with the carb on the bench. I was guessing the problem was this.
You are spot on, I have the air tube off. I also am not running any oil in the air cleaners. Would this also cause some air intake issues. I did this for two reasons. My originals where completely shot and we remade them for looks. I also thought I could give the motor a little shot of starting fluid to help it fire.
Look me up at the show, I will be the guy trying to get two 10-20 to fire. I will take them either way because I know I will find a group of guys to help tune them if I don't have them ready. thanks for the help.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
