Re: International A died and not starting
Posted by ScottyHOMEy on July 01, 2009 at 08:41:12 from (70.105.252.88):
In Reply to: Re: International A died and not starting posted by Larry Hardesty on July 01, 2009 at 06:46:34:
There are two types of 12v coils. One is essentially a 6v coil that DOES require a ballast resistor inline ahead of the coil. The other type is wound internally to provide the necessary resistance and DOES NOT require an external resistor. You have a paint problem on the existing, but a new one should be clearly marked as to which it is.
In no case would there be a resistor inline between the coil and the distributor.
