Re: H vs. Super H??
Posted by D Slater on July 01, 2009 at 09:09:47 from (72.65.152.136):
In Reply to: H vs. Super H?? posted by Jerry Wallen on July 01, 2009 at 08:36:51:
If you were looking at a late 53 H and a early 53 SH it could be hard to tell, so I would check that the engine is a C-164. If its a earlier H or later SH there,s several more differences. Date codes would be one thing. Most H except serial # 391358 and after used steel brake covers and all SH used cast brake covers (disc brakes) held on by 5 cap screws and they just had a bolt with spring that screwed in or out to adjust. Starters could be changed easy but only the late H with disc brakes and the suppers came with a starter switch mounted on top of starter and operated by a rod. Late SH used a center housing that the starter mounted with 3 bolts. Rest of H and SH used 2 bolts
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
