Re: 756 gas starts then dies
Posted by pete 23 on July 01, 2009 at 10:41:44 from (173.87.14.132):
In Reply to: Re: 756 gas starts then dies posted by Tractordummy on July 01, 2009 at 06:00:14:
If tractor is wired correctly it is negative - ground so neg - terminal of coil will be going to the points and you would hook hot battery wire to positive + side of coil. It will run eiether way but spark to plug would be reversed polarity and not proper. Just be sure you run current (hot wire) through coil, out other side to points and not directly to the points as that would be a short circuit, fry wires time.
