Re: M loss of power
Posted by Janicholson on July 01, 2009 at 13:58:49 from (64.61.211.186):
In Reply to: Re: M loss of power posted by KAC on July 01, 2009 at 13:41:41:
The needle is not "in the jet" it is a separate deal that adds to or "adjusts" the total fuel.
The jet enlargement can change total flow just from changing the contours of the passage. It can even reduce the flow, in some cases, by changing the fluidic nature of the passage. The main thing is to get it back to a known flow, then the load screw will adjust any extra needed. I would guess that the load screw can be screwed in all the way (gently) and it will still run well at High speed. Which it should get leanish. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
