Re: M loss of power
Posted by D Slater on July 01, 2009 at 14:23:44 from (72.65.152.136):
In Reply to: M loss of power posted by FarmallFred on June 30, 2009 at 18:08:56:
IH used a .061 main seat with there fire crator package. They also changed the air bleed size and a few other things along with that. Also the distributor advance was changed. Original M gas main seat was .0545. Don't know what you are calling a little. I would check the distributor advance parts and the timing before blaming the carburetor though. What heat range are the spark plugs? Its not unheard of to get a bad electronic ignition or the wrong unit. Also make sure the governor and linkage it moving the butterfly in carburetor to wide open when it starts lugging down. Also is the air cleaner clean.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
