Re: oil leak TA plunger 1486
Posted by pete 23 on July 01, 2009 at 19:02:50 from (173.87.14.132):
In Reply to: oil leak TA plunger 1486 posted by Larry B 1486 on July 01, 2009 at 18:23:06:
The plug does screw out and entire valve can be pulled out. Trick is to get a wrench on it as it has just two flats if it is original equipment. Easy with the special wrench made for it, I made one. Plug has o-ring inside , thing here is the o-ring should be a nice soft one so I would get the correct one from CaseIH if possible. Then upon reassambly make sure snap ring on valve contacts nut when in direct drive and spool is fully pulled out when in TA.
