Posted by pete 23 on July 01, 2009 at 19:20:35 from (173.87.14.132):
In Reply to: Farmall H carb problem posted by Harold Evans on July 01, 2009 at 19:07:27:
I would check the screen at the inlet to carb. When you have it off, turn on gas at tank and you should have a nice full stream coming out of pipe. Also, take plug out of bottom of carb or open petcock if it has one to see if a constant flow will keep on coming with fuel line hooked up again of course. So far as the drip when shut down, your needle and seat are most likely the problem but would not be cause of engine not running unless crud is plugging inlet to seat and also keeping needle from sealing good. Lots of problems with getting them to seat properly. I always "coin or stake" the seat but you need something with same degree angle as the needle to do this. Few very light taps will shape the seat so it holds. I use an old pintle from an injection nozzle to do this. Not something everybody has laying around of course.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
