Re: Adding hyd. outlet to Farmall M
Posted by john d on July 02, 2009 at 09:02:26 from (69.130.164.121):
In Reply to: Re: Adding hyd. outlet to Farmall M posted by Janicholson on July 02, 2009 at 08:34:11:
The delay on mine operates as long as the loads are even close to being similar. With a VERY light load on the rear port, it does have a tendency to raise early or simultaneously with the front. With a 3" cylinder on the planter harrow, and a 3" cylinder on the planter, the timing is a perfect delay in 4th gear. The cultivators worked the same way. Back in the 50s, we ran 2-row units on the H and M, delay was perfectly timed in 4th gear. Four-row unit we used in the 60s and 70s worked the same way.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
