Posted by Owen Aaland on July 02, 2009 at 09:32:23 from (65.165.246.156):
In Reply to: 221 engine posted by Travis b on July 02, 2009 at 08:15:18:
Travis b said: (quoted from post at 08:15:18 07/02/09) I threw a rod yesterday in my 460 international loader. Block done broke! Sheared off both of the connecting rod bolts and banged off my crank. Question is - Now i have to find another engine or at least a short block that is reasonably priced. Been looking around and was wonderin' if a 263 - 291 will bolt up. willing to try most anything. Does anyone within a couple hundred mies of upstate new york know of anything available?
The blocks will interchange. The 263 uses the same block with a longer stroke crankshaft. The 291 uses the came crankshaft as the 263 with larger bore block.
A lot of combines used similar engines that will fit but you have to change the front cover and plate, and use the tractor oil pan.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
