Re: Farmall H carb problem
Posted by glennster on July 02, 2009 at 09:35:52 from (99.135.95.186):
In Reply to: Farmall H carb problem posted by Harold Evans on July 01, 2009 at 19:07:27:
to add to what pete said, some of the other problems i ran into on my h carb, the float was a little crooked in the carb and would catch on the side of the bowl, also, check to see that the cross pin that holds the float in stays in the bracket. also, check the bowl gasket, i had one that was a little too wide and stuck into the bowl and would hang up on the float. for a simple carb, that lil rascal will make ya pull yer hair out!!!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
