Re: difference of front hubs on farmall m
Posted by mkirsch on July 02, 2009 at 09:50:34 from (64.80.108.56):
In Reply to: difference of front hubs on farmall m posted by Big Red Ed on July 02, 2009 at 08:33:34:
There are two types of front hubs. One is the fixed width type that clamps the wheels. The other is the adjustable type with loops on the rim that can be bolted to the inside or outside of the hub, and the rim flips over, for four different tread widths.
This sounds like the adjustable hub.
You don't have to take the hub off to get the rim off from the inside. Jack the tractor up, unbolt the rim from the hub. Drop the rim and tire straight down, then swing the bottom of the tire out past the hub. Lift the tire up and over the top of the hub. It's off.
