Re: difference of front hubs on farmall m
Posted by D Slater on July 02, 2009 at 10:01:30 from (72.65.152.136):
In Reply to: difference of front hubs on farmall m posted by Big Red Ed on July 02, 2009 at 08:33:34:
Those are not notches for the rim, the DA wheels were not made as heavy. Rims and wheels were made to have variable tread settings. Rim can be dished in or out and mounted on inside or outside of wheel. The DB wheel is made thicker for more strength where the bolt holes are, thats the reason they don't have what you call notches compared to DA wheels. Also the DB wheels were made to have a better fit with rim. IH came out with the DB wheel around late 51 or early 52 and then the DB was sold for as replacement wheels for earlier ones. Unless you have a big tire on the rims they can be removed and installed on inside of wheels without removing wheels. Sometimes it seems impossible, but if moved right the rims will pass over wheels.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
