Farmall H seals
Posted by Farmall Bob09 on July 02, 2009 at 17:08:57 from (75.220.43.191):
I recently ordered a seal for each side to do behind the brake drum, after reading posts and noticing that the older seals were twice as thick, I ordered another set...so I installed two on each side, using chassis grease between them, everything went good and they are in...my question is now I am at the outer seal for the rear axle and that too looks twice as thick. Do you guys recommend two seals in each cap? Because right now I only have two(one for each side) but can order two more if need be. Thanks for help as always.
