Re: SM farmall
Posted by D Slater on July 02, 2009 at 18:18:29 from (72.65.152.136):
In Reply to: Re: SM farmall posted by Charles E. McNelly III on July 02, 2009 at 16:05:09:
Charles I would say the tractor started as a LP from the farmall plant. If the engine is original it may have a C after the engine serial # or below it. Does it happen to have a gear reduction starter on it?
