Posted by Owen Aaland on July 03, 2009 at 07:32:53 from (65.165.246.156):
In Reply to: 1066 Problem posted by craig Reavley on July 03, 2009 at 06:44:08:
The only thing the PTO shares with the hydraulics is the common reservoir. The PTO has it's own hydraulic pump and intake filter/screen.
If the PTO has slipped you are going to have to do a total rebuild, not just a clutch pack replacement. Once it slips it ruins the piston seal with the heat generated. The brake pistons are probably worn out also.
It is not a really difficult job but it does take a few tools that most people will not have. Once you remove it from the rear frame you will need some way to compress the springs to remove the snap rings. It also takes a rather special hydraulic fitting to adapt a pressure gauge to the test port to set the hydraulic pressure after the job is done.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
