Okay guys, laugh at me. I bought a 560 it had no lights, it had two 6 volt batteries mounted to the side of it instead of under teh hood for easier access I presume. It is a diesel so have to run the glow plugs about 90 seconds before I crank. They are those long narrow batteries hooked together in series which i guess is how I come up with 12 volts. I rewired all of the lights from the rotary switch, it has 4 positions, Off I presume, Dim, Bright and without Rear Light ( or maybe I hooked up something wrong - quite possible ) the lights all work and the generator has been changed to a GM alternator.
I just tested for continuity on the rotary light switch and then hooked up the lights accordingly. My 560 has square fenders like a 656 and I added two outside lights to those. I hooked up the fender lights to come on when the two lights come on that are on the pipe bars that come from the center console area like on your 400. It is the same rotary looking switch as we had on our 400 LPG that I grew up on.
I have no idea if our 400 was 12 or 6 volt all I can tell you is dad had a 12 volt battery under the seat. I do not recall seeing a large resistor or diode on it anywhere from jumping it many times over the years. It was a hard starter. The starter was notorious for sticking and you would have to put it in road gear and rock the tractor furiously to get it to disengage if you were lucky and did not have the blade or implement on the rear on the ground or the loader on the front dragging. Not sure if that had anything to do with the 6/12 volt issue.
Not sure if this helps a lot but there was an obvious hot wire for the switch and a ground. I just used jumper wires from the battery posts and a 12 volt test light to see what position on the switch lit up when I moved it and checked the other spades on it to see if any of them were hot at the same time.
I highly recommend a volt meter, 12 and 6 volt test light of some sort with alligator clips or ice pick point on it and a way of testing continuity.
I am not sure of the other parts where you need a resistor and diode. So far I have not experienced any smoking switches or wires and my tractor has not caught on fire. I guess I am just running on dumb luck. THe Amp MEter shows charging properly unless I have all 5 lights ( one in rear ) and am under 600 - 800 rpms and then i show discharging.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
