Re: SM hydraulic filter
Posted by D Slater on July 03, 2009 at 18:08:22 from (72.65.152.136):
In Reply to: SM hydraulic filter posted by cazzhrdwd on July 03, 2009 at 15:08:46:
This is just a suggestion. A SM system is not that hard to take apart and clean up first even if a screen or filter is used. Don't know which hydraulic system you have on your SM. When I had one with live hydraulic , resevoir under tank and a aftermarket valve bank, I used a filter in the return line to reservoir from valve bank. If you put something in suction it needs to be sized to stop unwanted particals but open enough that suction is not restricted to much.
IH came out with a suction screen package 363278 R91 for the reservoirs under gas tank that went in behind the suction elbow. Doubt if you could find one now.
