Re: mowing with M with hi-lo in transmission
Posted by Randy-IA on July 03, 2009 at 19:13:35 from (207.177.83.71):
In Reply to: mowing with M with hi-lo in transmission posted by JiminIowa on July 02, 2009 at 14:39:02:
If it's a M&W 9 speed it doesn't effect the low range speeds to the pto according to the installation manual. It only speeds up the first four gears and the pto in the high range. You don't have to run it at wide open throttle if you use the high range. HTH. ...Randy
