Here's one. It is one of the more buggersome things that can run you nuts on a mag, but it still holds even when you're using only the distributor end of the mag, as you are.
That is the wire between the condensor and the points. They have been known to chafe or be kinked or have the insulation crack, causing a short to chassis through the wall of the narrow passage that wire is routed through to get to the points.
And, just because it never hurts to ask, you do have the switch in the "ON" position, right? I'd rather not describe on a public forum the experience that causes me to toss that out.
Also, do lights and so on work, as in you have a good battery with good connections to hot and ground.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
