Re: Super A Quits When Hot
Posted by Andy Motteberg on July 03, 2009 at 20:35:14 from (4.143.216.14):
In Reply to: Super A Quits When Hot posted by DEEPNHOCK on July 03, 2009 at 19:05:19:
Does it have a external resistor by the coil, or a coil with a internal resistor? A 12 volt system MUST have a resistor. Also, get rid of the in-line fuel filter, they can cause problems and you don't need one. The sediment bowl and carb screen filter good enough.
