Re: Super A Quits When Hot
Posted by El Toro on July 04, 2009 at 03:36:35 from (64.12.116.73):
In Reply to: Super A Quits When Hot posted by DEEPNHOCK on July 03, 2009 at 19:05:19:
When it quits pull one of the plug wires & check for fire to your plug, do this asap before it cools. If there's no fire replace the condenser.
If it keeps quitting you need to make sure battery voltage is still getting to the coil. Use a test lite or volt meter & with the points open you should have voltage on both small terminals on the coil. If you have fire to your plugs you have a fuel problem. Look in the tank with a good flashlite to see if any rust or dirt is covering the outlet. Pull the gas line at the carburetor and see if there's a full stream of gas there. If that looks ok check behind the tube fitting where your gas connects and see if there's screen behind it that may be full of crud blocking the fuel flow. Hal
