Re: Super A Quits When Hot
Posted by Hugh MacKay on July 04, 2009 at 03:38:01 from (216.208.58.157):
In Reply to: Super A Quits When Hot posted by DEEPNHOCK on July 03, 2009 at 19:05:19:
Jeff: Heave the inline filter over the nearest cliff. Restore the gas line and sediment bowl with screen to factory specs.
There is one other item, if the problem is fire to the plugs. Your distributor shaft could be worn and needs rebuilding. If this is the case tractor will usually stop when you hit a bump or other type of jolt. It doesn't have to be hot on this one. It happened to my 130 about 20 years ago, I'd get jolts when plowing snow or hitting a pothole on a gravel road, bingo she would stop, but fire right up immediately.
