Just thinking of causes of over-heating--is the fan belt in good shape---is the fan turning easily-bearing not dragging? You said that the radiator fins are free of dirt & air moves freely through the radiator? Maybe a radiator hose has a piece of the inside rubber coming loose & blocking coolant flow? Is the timing set correctly? How about the valve lash---set to specs?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
