Re: Super A Quits When Hot
Posted by Brownie 450 on July 04, 2009 at 07:56:20 from (216.51.158.133):
In Reply to: Super A Quits When Hot posted by DEEPNHOCK on July 03, 2009 at 19:05:19:
We never had a SA--does it have a water pump? Possibly a bad bearing in the pump--impeller came loose from the pump shaft?
