Re: Super A Quits When Hot
Posted by DEEPNHOCK on July 04, 2009 at 13:44:46 from (67.142.161.22):
In Reply to: Re: Super A Quits When Hot posted by John G. Hasler on July 04, 2009 at 05:23:26:
Solved it.....
But here's what I did first (after all the stuff in the first post)...
Put a voltmeter on the supply side of the coil.
Ran the tractor until it did it's hiccup/quit thing.
Stared at the voltmeter looking for a dropoff.
Stayed at 12 volts the whole time.
(Had a jumper wire ready to try to see if it might be a bad ignition switch, as suggested above).
Finally told myself (for the eleventeenth time) that it is not electrical and went over to the fuel side again.
The only thing I had not tried was rebuilding the carb (no kit in hand)...
But I had already taken the Zenith apart and cleaned it thoroughly (without adjusting anything other than the idle mixture screw)...
Looked up the float setting for a Zenith in my Allis Chalmers service manual (because I have none for a Farmall)...
Set the float just a tick higher than it had been.
Fired her up and went out with it.
Ran the cultivator more than a mile with no problem at all.
Am going to get a carb kit and install it for good measure.
My supposition is a combination of a slightly low fuel bowl level coupled with the crummy gas we are being sold these days.
Thanks for the ideas. I really was scratching my head, and that says a lot.
Thanks all!
Jeff
