Re: Char-Lynn hydraulic valve
Posted by Armand Tatro on July 04, 2009 at 15:39:05 from (71.239.10.80):
In Reply to: Char-Lynn hydraulic valve posted by Terry Bahler on July 04, 2009 at 14:03:34:
Not familier with your valve but my idea would be to disconect pressure line from where it enters hyd. res., connect pressure line from pump to charlyn valve, than output from char-lyn valve to hyd. res. These valves need to be hooked in series. However somebody more familier with the char-lyn valve may have a better idea. I have plumped valves in series on farm tractors and trucks and had good luck. You may need to chance the pressure relief on the charlyn valve if it is rated higher rhan the pump output. I would like to see a picture of that Char-lyn valve and also a picture of where the pressure line from the pump enters the hyd. Res. I know werer the suction line comes out of the hyd. res. Armand
