Re: IH240U Grinding noise
Posted by Szrachnor on July 04, 2009 at 17:26:25 from (68.118.189.13):
In Reply to: IH240U Grinding noise posted by IH 240 Utility on July 04, 2009 at 17:05:07:
Did you adjust the fingers on the new pressure plate after installing it? Most new clutches do not come with pre-adjusted fingers and this might be causing it to release unevenly. Your clutch housing is webbed underneath so if your careful you can get under the left side of it with a flashlight and watch the clutch shaft come to a halt by pulling down on the clutch pedal.
-Leon
