Re: Farmall 504 clutch
Posted by Machine249 on July 04, 2009 at 19:01:01 from (76.100.246.141):
In Reply to: Farmall 504 clutch posted by Daniel Vader on July 04, 2009 at 09:46:09:
The clutch kit is about $250. As far as installing it your going to have to split the tractor. If you can rig some sort of stand to support the frame rails and support the rear of the tractor near the clutch housing, you should be able to remove the engine bolts and the frame rail bolts at the clutch housing and seperate the two enough to replace your clutch. Even if you have to disassemble the whole front, it shouldn't be more than a days work to complete.
