Re: W4 quits when hot
Posted by Janicholson on July 04, 2009 at 22:05:04 from (64.61.211.163):
In Reply to: W4 quits when hot posted by Eric Bergstrom on July 04, 2009 at 15:25:47:
In addition to the good ideas below, I would add that a compression test just as it quits will tell you if it has a loss of compression causing issues.
Hot engines do crank faster than cold engines, but it might be worth a check. (hold the throttle open while checking) JimN
