Re: Farmall A Belt pulley gear box
Posted by Hugh MacKay on July 05, 2009 at 02:15:02 from (216.208.58.126):
In Reply to: Farmall A Belt pulley gear box posted by Tom Fleming on July 04, 2009 at 19:55:09:
Tom: This is a slow process unless you get it right first try. After you have pulley installed, remove the fill plug, and you can see those gears. Your supposed to be able to put a narrow strip of thin shim stock through mesh of the gears. It should be tight enough to form up the gear pattern in shim stock, yet not make any harsh gouges into shim stock.
Second problem, don't know where you'll find shim stock and in most cases they won't know what your talking about. Best to use aluminum beer or soda pop can. I guess in all fairness, those two products have put shim stock manufacturers out of business.
