Re: IH240U Grinding noise
Posted by Hugh MacKay on July 05, 2009 at 02:27:06 from (216.208.58.126):
In Reply to: IH240U Grinding noise posted by IH 240 Utility on July 04, 2009 at 17:05:07:
IH240: You replaced clutch, pressure plate and throw out bearing. How about the pilot bushing? A bad pilot bushing can cause the problem you mention.
It could also be those fingers on pressure plate need adjusting.
A third factor, you may be just too impatient, after all this is 1950s technology not a modern day standard shift with transmission brake. We always had to throttle those tractors down for getting them in gear from standing idling.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
