Farmall A: Since bush hog wouldn't be a problem, you can perhaps do something cheaper than a 3 point hitch for the blade. Fabricate a pivot that bolts to U type drawbar, with provission for lower link pins of blade to pivot in. Then run a cable from top link, under the platform to a boat winch mounted to clutch housing, or one of the A hand levers. I saw another novel idea, guy had a reduction gear box with a lever for pulling cable to lift blade and a wheel on the input shaft much like the old road graders. He had separate controls for each side of blade.
Go look at both old and modern road grader, it will give you numerous ideas. Don't modify the blade, you may have a 3 point hitch tractor sometime.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
